Patislas
I'm using verilog models of a dual port ram memory. When operations are done simultaneously at the same address on the two ports without respecting the Tcc timing constraint a collision occurs, WriteA/ReadB for example. In this case the Read on the port B fails and the output is corrupted (put at X). In order to check the Tcc timing constraint the task $recovery is used: $recovery(posedge CLKA &&& csba_en,posedge CLKB &&& (flag_collisionB ==1'b1), tcc, warningCCB); Using this task makes it possible to back annotate the tcc timing constraint (with SDF file) and to check collision violations.
Unfortunately the $recovery task generates an error message in the log when the collision occurs. I do not want to have these error message, so I was wondering if it is possible to skip this error messages, or to modify this system task in order to delete the error message. Any idea ? Thank you
