Aug 27th, 2024, 11:17pm
Pole Zero (PZ) analysis (Read 6475 times)
analogrf
Apr 14th, 2011, 8:33am
I have a complex system with many poles and zeros. I used spectre's PZ analysis to get the accurate locations for my circuit. However i want the PZ analysis to tell me the associated node of each pole or pole-zero pair.
Is it possible to get to know the associated node of each  pole/zero too ??
Best Regards
ARF
Garrett.Neaves
Analog Design
Engineer
United States
Re: Pole Zero (PZ) analysis
Reply #1 - Apr 14th, 2011, 10:28am
analogrf wrote on Apr 14th, 2011, 8:33am:
It can occur that a particular pole or zero is associated with a particular node or can be approximately associated with a particular node.  However, in general, a specific pole or zero is not associated with a specific node.  It is possible to derive transfer functions in symbolic factorized pole-zero form which allows the poles and zeros to be identified in terms of the circuit elements.  The derivation is performed primarily with pencil and paper.
analogrf
Reply #2 - Apr 14th, 2011, 11:04am
Thanks indeed for the reply.
You can think of it as this: One can enter the derived small signal schematics in spectre to get a clue of where the poles and zeros are. So lets say the manual analysis reveals 4 poles and 2 zeroes, then spectre also plots the exact 4p and 2z using PZ analysis.
What i wanted to know was, if one can track which respective nodes are each of these coming from (now they are associated with the SS model nodes ! ) . Lets say when they are close to each other, its difficult to predict which one is coming from node x and which one from node y.
AnRF
Garrett.Neaves
Analog Design
Engineer
United States
Reply #3 - Apr 14th, 2011, 12:37pm
analogrf wrote on Apr 14th, 2011, 11:04am:
The PZ simulation is always performed on a small signal model.  This small signal model can be one created by the simulator from the DC operating point of a circuit with non-zero DC biasing.  Or it can be the small signal equivalent circuit entered into the simulator by the user.  In either case, if the user manually derives a transfer function, then the user will find that , in general, the poles and zeros of that transfer function do not have a one-to-one correspondence to individual nodes of the circuit.  The poles and zeros are, in general, functions of any of the elements in the circuit.
A pole or zero in radians per second is equal to the reciprocal of a time constant.  For example, a simple RC time constant.  The R can be between a pair of nodes in the circuit and the C can be between a different pair of nodes.  In this  example, then, their are 4 nodes which correspond to the pole or zero.  And therefore, I think the question of tracking which node is associated with a pole or zero can only be answered by explaining that the question contains an incorrect assumption.
There are situations in which both the R and the C are connected between a node and AC ground, and there are situations where this is an appropriate approximation, but, it is not the general case.
raja.cedt
Reply #4 - Apr 14th, 2011, 10:09pm
hi,
plot each nose phase shift, so this gives some clue.
Thanks.
