Apr 27th, 2024, 1:06pm
How to calculate phase noise of a frequency modulate signal (Read 2719 times)
icemc2008
Apr 18th, 2011, 1:09am
Hello everyone,
I am a newbie in phase noise and jitter. I want to ask how to calculate the phase noise of a frequency modulate signal.
Ex: I have a sine wave of 10MHz and 0.5V - > - 0.5V amplitude. a modulation signal: a sine wave with 10kHz frequence and 1MHz amplitude(deviation).
I want to calculate the phase noise of this modulated signal. please give me a expression and example to calculate it with the data above.
please help me, thanks a lot for your kind and patience!!!
raja.cedt
Re: How to calculate phase noise of a frequency modulate signal
Reply #1 - Apr 18th, 2011, 11:11am
hi,
most of the noise in oscillators coming from phase so forget about amplitude noise. Coming to the phase noise, it is the single side band noise to carrier power ratio. But for the present scenario you have given its mainly spur level rather than calling as phase noise, because there only one noise component @ 10k so it reflects as noise spur at your oscillator o/p. spur level is 20log(beta), where beta=frequency deviation/center frequency. Just read FM basics.
get back to m if you have any questions..
Thanks.
Raj.
