Aug 17th, 2024, 3:26am
TL Modelling (Read 690 times)
unevb
TL Modelling
Apr 21st, 2011, 1:28am
I am trying to find the S-parameters of a integrated Coplanar Waveguide using Agilent's Momentum tool... The signal line is on the top metal layer of a 9 metal stack and I have 2 GND lines running parallel to the signal conductor on both sides of it.
I define 4 ports :
1. Port 1 : Top of the Signal line
2. Port 2 : Bottom of the Signal line
3. Port 3 : Gnd line on the left
4. Port 4 : Gnd line on the right
I get a *.s4p from after my simulation. In my ADS schematic simulation, I connect Port 3 and Port 4 to the reference ground plane , and use the TL as a 2 port device.
Is there a way to accurately extract the S-parameters at a 2 port (*.s2p) from the EM simulations itself? In other words, is there a way to specify that the conductors on the sides of the signal line are GND lines, in the EM simulation. I need a 2-port S-matrix because I want to convert the S-parameters to ABCD to find out the Zo and gamma of the TL
Thanks!
Re: TL Modelling
Reply #1 - Apr 21st, 2011, 11:47am
Simply resimulate 4port-sp box as 2port by sp-analysis.
Here connect gnd to port3 and port 4.
unevb
Re: TL Modelling
Reply #2 - Apr 24th, 2011, 2:21pm
Thanks, that works well.
For calculating the Zo, I am converting the S-parameters to ABCD parameters
A = cosh( gamma * l)
B = Zo * sinh (gamma * l)
C = sinh (gamma * l) / Zo
D = cosh (gamma * l)
I am using B/C to estimate the Zo of the line. Is this a correct approach?
The Zo varies a lot with frequency (Fig1 from Matlab).  In Fig.2 (from ADS), I have terminated the TL with 95-ohm (Zo at 20GHz) ,  the input impedance is approximately 100-ohms. For higher frequency Zo is much lower though.
In such a case, how come people talk about 100-ohm TL without specifying the exact frequency range over which this is true?
