Aug 17th, 2024, 1:12am
Power supply coupling modulate VCO (Read 2847 times)
daxigua179
china
Apr 25th, 2011, 1:08am
I am wondering about whether  power supply coupled with a large tone, which  will modulate VCO to cause large spur at VCO output, how can I simulate it? I try to use QPSS, but VCO frequency is autonomous, I don't know how to set it as one fund of simulation.
Re: Power supply coupling modulate VCO
Reply #1 - Apr 25th, 2011, 1:23am
Use PAC or PXF.
Reply #2 - Apr 25th, 2011, 3:13am
Daxigua,
    You might want to try semi-autonomous PSS analysis. It enables you
to include a driven signal with an autonomous signal. Semi-autonomous
analysis is a large signal analysis.
