Aug 16th, 2024, 11:18pm
PSS accuracy in oscillator simulation (Read 2405 times)
jqjqjq
Apr 19th, 2011, 12:09am
Hi everyone, I'm simulating an oscillator working around 3GHz
and I did the pss simulation to get the frequency.
Yet I want the simulation result to be a bit accurate , for instance,
to be within the accuracy of 10kHz, however, when I redid the
simulation without changing anything, the resulting frequency
fluctuated with about 100kHz at least, so my result seems to
have little physical meaning.
I wondered what should I do to increase the simulation accuracy.
I read the cadence design manual, the sections on PSS options form.
I tried change maxstep to 10p and steadyratio to 1e-8, but they never
worked.
Thanks for any helpful advices.
jqjqjq
View Profile jqjqjq   IP Logged
rfidea
Europe
Re: PSS accuracy in oscillator simulation
Reply #1 - Apr 25th, 2011, 1:19pm
Hi, first of all you should use "conservative" in the PSS settings to increase the tolerance. Then I think it is better to work with the basic tolerances, reltol, vabstol and iabstol instead of steadyratio. For example start with reltol=1e-5, vabstol=1e-8  and iabstol=1e-13. Since steadyratio is setting the tolerance of the whole fundamental period there is no point in tighten this without increasing the basic tolerances.
Then a question about your goal of 10kHz at a 3GHz oscillator. This is 3ppm! That is low, very low, much less than the tolerance of a crystla oscillator and I'm sure this is not a crystal oscillator.
