May 5th, 2024, 6:32pm
Fmax and Ft of a device (Read 5753 times)
afridi
Apr 21st, 2011, 3:43am
Hello all and this is my first post on this forum.
my question is what is Ft and Fmax of a semiconductor device? Can they be calculated from each other?   Smiley
The more things you do, the more you can do.(Lucille Ball)
rfidea
Europe
Re: Fmax and Ft of a device
Reply #1 - Apr 28th, 2011, 10:18am
Ft is the frequency where the current gain, drain/collector current divided by gate/base current with drain/collector grounded, is one.
Fmax is the frequency where the maximum power gain of the transistor is one.
Ft and Fmax is related but there is no simple relationship. For example the drain/collector capacitance will influence Fmax more than Ft since there is voltage swing there for the Fmax case.
raja.cedt
Reply #2 - Nov 12th, 2011, 10:34am
hello,
in adition to rfidea, Fmax measured under matched load condtion at the drain where as ft measured under short ckt load. you can find simple relation between these in Rf design by TH lee. Mainly that relation depends on the base resistance which impacts Fmax where as no impact on Ft.
raj.
