unevb
I am trying to use the HB analysis in Cadence Spectre (Version : IC6.1.3.500.13). I keep getting the following error : 'hb is an instance of an undefined model hb'
All other analysis (PSS,PAC,AC,DC...) work fine in the testbench, but whenever I want to do anything based on harmonic balance (HB,HBAC, HBNOISE) I see this problem.
Has anyone faced a similar problem? Is there a fix for this?
Thanks.
