Aug 16th, 2024, 9:20pm
Problem using HB in spectre (Read 2179 times)
unevb
May 04th, 2011, 2:46pm
I am trying to use the HB analysis in Cadence Spectre (Version : IC6.1.3.500.13). I keep getting the following error :
'hb is an instance of an undefined model hb'
All other analysis (PSS,PAC,AC,DC...) work fine in the testbench, but whenever I want to do anything based on harmonic balance (HB,HBAC, HBNOISE) I see this problem.
Has anyone faced a similar problem? Is there a fix for this?
Thanks.
Re: Problem using HB in spectre
Reply #1 - May 4th, 2011, 8:45pm
Unevb,
   IC61 is the version of Virtuoso and not Spectre.
