Jul 18th, 2024, 6:32am
strange error when using Verilog-A blocks (Read 3461 times)
dxt78
Ohio
May 08th, 2011, 3:57pm
I'm getting a strange error when using two Verilog-A blocks (pic attached) together.  I test each block on their own and they work fine.  When I try to use them together though, I get this error:
"ERROR (CMI-2116): I3: Too few terminals given (3 < 4)"
The first block ("min_block") takes three voltages and finds the minimum.
The second block ("subtract_block") takes two voltages and outputs the difference.
My Verilog-A for the min_block is:
"`include "constants.vams"
`include "disciplines.vams"
module min_block(x, y, z, out);
     electrical x, y, z, out;
     analog begin : themodule
           real vx,vy,vz;
           real temp, temp2;
           vx = V(x);
           vy = V(y);
           vz = V(z);
           temp = min(vx,vy);
           temp2 = min(temp,vz);
           V(out) <+ temp2;
endmodule"
And my code for the subtract_block is:
module min_block(x, y, difference);
     electrical x, y, difference;
           real vx,vy;
           real temp;
           vx = V(x);
           vy = V(y);
           temp = (vx - vy);
           V(difference) <+ temp;
dxt78
Ohio
Re: strange error when using Verilog-A blocks
Reply #1 - May 8th, 2011, 4:13pm
Edit: ok sorry I actually found the problem.  I created the 2nd block, from the first, but forgot to change the module name!
