Apr 28th, 2024, 12:01pm
Noise Simulation of Continuous Integrator and SC Amplifier (Read 3614 times)
analog_design
INDIA
May 12th, 2011, 11:42pm
Hi Guys,
I am really facing problem while doing noise simulation of Continuous TIme Integrator. I am using Spectre simulatior
Which is correct method to do noise simulation ?
noise in ADE or
PSS, PAC and Pnoise
Please, explain me detail steps to do noise simulation. I have done analysis with above method. but, I am not confidence whether it is correct or not ?
If you have any doc or suggested book on noise simulation / analysis then please let me know.
Thank You.
Warm Regards
View Profile analog_design   IP Logged
Re: Noise Simulation of Continuous Integrator and SC Amplifier
Reply #1 - May 13th, 2011, 8:51pm
Analog Design,
  It would help if you would explain what your problem is. Is your
problem that you don't know which tool to use? How to use the tools?
The results are not consistent with hand calculation? The results are
not consistent with measurement? ...?
  Next, sorry I am a little bit slow. Why would you be using periodic
steady-state analysis to analyze a continuous time integrator? Does
the integrator have reset? Is it used inside a loop, for example, the
controller in a dc-to-dc converter?
  Also some comments:
1) ADE is the simulation environment and Spectre is the simulator
2) Spectre performs both  linear noise and periodic noise analysis
3) Manages the pre-simulation setup and post-simulation analysis
analog_design
INDIA
Reply #2 - May 18th, 2011, 8:57am
Hi Sheldon,
I am sorry I have passed incomplete information.  Please go through an attached block diagram. after  resistor there is one MOSFET switch. this is kind of design of  integrator.  Resistor is fixed. instead of DAC i am using fixed bias for time being.
Please, let me know how can characterize / analysis this design like
Noise simulation, Time domain analysis. Is correct way to do small signal noise simulation in cadence or  PSS, PAC and Pnoise simulation.
Please, let me know in detail. I would be thankful to you.
Warm Regards,
Analog_Design
Warm Regards
analog_design
INDIA
Reply #3 - May 18th, 2011, 8:59am
analog_design wrote on May 18th, 2011, 8:57am:
Hi Sheldon,
Warm Regards,
Analog_Design
Warm Regards
