![](https://designers-guide.org/forum/avatars/fredflinstone.gif)
Best Design Tool = Capable Designers
if it is just a current mismatch, then the problem is no big deal - you get a higher current for pump up or down, changing the BW response characteristic a little.
When you are talking spectral spurs, thats a different issue.
