Aug 29th, 2024, 1:21pm
Urgent - Strong vs Weak inversion (Read 3945 times)
pcardoso73
Portugal
May 27th, 2011, 12:02am
Please try to help me out on this. I am simulating a VCO using 130 nm technology.
As BJT's have a lower flicker, I tried the simulation on weak inversion for the MOS, expecting a better behavior than in the strong inversion, in terms of 1/f and 1/f^3. But, by simulations, I cannot reach this conclusion.
Any ideas ?
Best regards,
Pedro
solidstate
Munich, Germany
Re: Urgent - Strong vs Weak inversion
Reply #1 - May 27th, 2011, 10:53am
As far as I know, a mosfet does not become a BJT by biasing it in weak inversion, it just shows similar characteristics. The main reason BJTs have low 1/f noise is because they are not surface devices; 1/f noise in mosfets is due to defects at the Si/Si02 interface. The only solution to reduce that noise is by increasing device area..
rfidea
Europe
Reply #2 - May 27th, 2011, 11:38am
solidstate wrote on May 27th, 2011, 10:53am:
I have the same opinon.
aaron_do
Reply #3 - May 28th, 2011, 8:17am
Hi Pedro,
the signals in a VCO are large. So I'm not sure that it's fair to say its in the weak inversion or strong inversion region, since more likely it goes from off to weak inversion to strong inversion and finally to triode region, and then back again. There are a few papers on VCO phase noise around, so probably they will have better information.
cheers,
Aaron
pcardoso73
Portugal
Reply #4 - May 28th, 2011, 10:43am
Thank you for your replies. Maybe I wasn't very clear. Well I know that both devices are different. Please notice that, in weak inversion, the MOS device operates according an exponential law rather then operating according to a square law. Thus here is some similarity with BJT's. With this assumption, I was expecting that the exponential law behavior would cause a better noise performance.
As  solidstate said I just need to increase the size of the MOS to get better 1/f noise, but that is to go in the direction of weak inversion.
Moreover I will have more problems wih parasitic capacitances of the transistor if the gain of he mosfet is high.
Concluding, how is it possible to have a good phase noise behavior on weak inversion  ?
Tanks to all.
Pedro
Reply #5 - May 28th, 2011, 6:11pm
do some research on phase noise in VCO's there are many papers out there.
IEEE JSSC is your friend here.
