trying to simulate a chopper amplifier input referred noise. The use of spectre RF seems appropriate enough.
For the direct plot which option should I choose SSB noise, DSB noise ect. ?
I am using the following pnoise, pss settings:
pss pss fund=100k harms=3 errpreset=conservative
+ annotate=status
pnoise ( out 0 ) pnoise sweeptype=relative relharmnum=1
+ start=1 stop=50k log=20 maxsideband=20 iprobe=V2 refsideband=0
+ annotate=status
The direct plot input refered noise does not seems to reduce the flicker noise. have also tried following the chopper opamp with a with a sample and hold and taking the output for pnoise simulation from the sample and hold but this still does not reduce the flicker noise seen on the direct plot when using SSB noise for input refered noise.
I've read Ken Kundert's sc-filters.pdf from
www.designers-guide.org/Analysis/ .
Any ideas where I'm going wrong with the simulation setup and direct plot?
harmonic
