jb_savage
Can someone comment on using Spectre/SpectreRF at 60GHz for transceiver design (LNA, VCO, PA, etc...) in mmwave? Is it out of the range for Spectre? Have high frequency models (TSMC N65) and Momentum created s-params for inductors. Agilent GoldenGate seems to work OK as does ADS. Using Spectre APS seems to get different results. Could this be because Spectre does work at 60GHz or maybe the APS model interpreting which I understand is simplified is too aggressive. I really don't like a simulator that is messing with the model parameters and accuracy. Or, maybe I am expecting too much from Spectre at 60GHz.
