Sep 1st, 2024, 11:31am
Pages: 1 2 3
miller compensatone (Read 5805 times)
RobG
Bozeman, MT
Re: miller compensatone
Reply #30 - Jun 21st, 2011, 7:00am
vivkr wrote on Jun 21st, 2011, 12:08am:
Rob,
Indeed, the most popular variant of this scheme is to return the feedback to the cascode. However, as you point out, that causes peaking. My experience was that this peaking makes life quite painful, so much so that you do not really reap the full benefits of using this scheme. It turns out to be better to just put the extra stage although you end up burning more power and adding an extra source of noise to your amp.
Vivek
What kind of amps are you building? It usually isn't a problem for me unless I'm driving a large DC current.
vivkr
Reply #31 - Jun 21st, 2011, 7:55am
well! I am not building any of those fancy amps anymore, but I did spend quite a while playing with all these topologies in an earlier job. There were different kinds of applications there for sensor interfaces.
I didn't use it for driving R-loads though as there were hardly any such applications. I found it quite handy as you can get away with very low compensation cap and still be stable. A very handy advantage if making high-voltage amps by the way as those caps can be rather huge and you want to save every bit of area.
Also tried it once when I had a tricky amp to stabilize but gave up on it because the noise requirements were too tight and it does give you more noise. I think I ended up using the return to the cascode in that one.
Vivek
sushan
Reply #32 - Aug 29th, 2011, 9:51pm
@Loose-electron: Can you please attach the circuit???
harpoon
Hampshire
Reply #33 - Aug 30th, 2011, 6:03am
100pF is just too wasteful (unless you have lots of silicon space) ...
try the following link for ideas :-
http://cmosedu.com/cmos1/bad_design/bad_design3/bad_design_3.htm
(I think it is similar to what vivek pointed out).
Reply #34 - Aug 30th, 2011, 3:58pm
sushan wrote on Aug 29th, 2011, 9:51pm:
See attached - Q10 & Q11 buffers the output and drives a feedback capacitor, Cc. Because of the Q10 source follower there is no high frequency feed forward.
harpoon
Hampshire
Reply #35 - Aug 31st, 2011, 1:28am
loose-electron wrote on Aug 30th, 2011, 3:58pm:
This is a classic "indirect feedback" topology that is much better than the standard (and outdated) Miller compensation (but uses a tiny bit more current)
However, I just wish to point out that this is also a classic output stage that is a bit "dangerous" as the output stage current is not defined properly.
Pages: 1 2 3
