Jul 18th, 2024, 6:26am
limit in spectreMDL outputs "*.measure"  files.... (Read 2612 times)
Evgenii
Jun 16th, 2011, 5:27am
Hi! I use "foreach" function in spectreMDL script, for example:
foreach VL from {1.65, 1.95, 2.3, 2.7, 3, 3.6} {
 foreach VCC from {2.3, 2.7, 3, 3.6, 4.5, 5.5} {
  run delay as typ_25
In my ".mdl" file i need repeat this construction for many temperature and many corners. i do this... But output ".measure" file do not contain all measurements. Output range of measurements in some places in file looks clipped.... May be "foreach" has memory limit or something else...
Thanks! Smiley
ps
version - spectre (ver. 5.10.41.020608 -- 06 Feb 2008).
and for run simulation i use: - $spectremdl -tab -b *.mdl
