May 19th, 2024, 3:24am
concatenate operation (Read 4127 times)
samy
Jun 16th, 2011, 7:19pm
dear all,
i want to concatenate a register(of dynamic size as for concatenation)
with n no:of zeros where n is a  generic integer number.
say for eg
num1_reg := "00" & num1;--here only two zeros are only used
i would like to make it something that would work like this
num1_reg := "N zeros" & num1;--wherein n is a generic number
how to make it work..please advice...
thanks in advance
boe
Re: concatenate operation
Reply #1 - Jun 17th, 2011, 1:51am
Samy,
Which language do you use?
B O E
samy
Reply #2 - Jun 17th, 2011, 2:19am
VHDL only not verilog
boe
Reply #3 - Jun 17th, 2011, 7:36am
Samy,
you could e.g. define a constant zero vector of sufficient size and use an N bit wide sub-vector.
B O E
samy
Reply #4 - Jun 17th, 2011, 9:12am
thanks boe.tat was of gr8 help
actually tat was not i was lookin for.the type-subtype wont help me b'coz the size of the main type cant be determined unless the n(for the zero's or for the main pgm) is assigned,moreover as you said the a large size for the vector is also not adviced i suppose!!
