Jul 17th, 2024, 7:18am
transformer optimization for power amplifiers (Read 2092 times)
aaron_do
Jun 17th, 2011, 12:17am
I have often seen papers where a transformer's performance is measured by its maximum available gain (MAG). However, in a power amplifier, we are not trying to achieve matched conditions at the output. The conditions which lead to MAG of the transformer may not lead to optimum output power or efficiency.
My questions are, what is a good way to determine transformer insertion loss, and do we know if the insertion loss is optimized?
thanks,
Aaron
Re: transformer optimization for power amplifiers
Reply #1 - Jun 17th, 2011, 3:07pm
empirical for an existing element or theoretical for a design in progress?
Sonnet or AWR has tools for the EM models of a design in progress.
Empirical testing? Have to design a test platform with appropriate balanced paths and calibration for a testing method. Somewhat similar to a test setup for a filter inserted into an RF path.
aaron_do
Reply #2 - Jun 17th, 2011, 4:40pm
I think my question wasn't phrased very well. I know how to use an EM simulator to extract an S-parameter model of a transformer. My question is on the theoretical side for a design in progress.
I am using the transformer in a power amplifier, and I have found that the insertion loss I am getting is quite a bit poorer than the maximum available gain of the transformer. But I know that I shouldn't be getting the MAG of the transformer anyway, because I am not trying to match the output to the load. So how do I know my transformer is being used optimally? I am thinking I need to do a load pull simulation and look at my required output power contour to see the optimum load impedance, and then use this info to modify my transformer, or possibly add matching of some kind.
thanks,
Aaron
inductioner
Reply #3 - Jul 26th, 2011, 4:32am
Transformer's insertion loss can be considered as an independent parameter during initial PA design phase. It only hurts your PAE, but does not affect impedance transformation behavior. One simple way is to set IL=0dB in the first place and go back to run with EM model.
aaron_do
Reply #4 - Jul 26th, 2011, 6:26pm
Hi inductioner,
thanks for the reply. Actually that is how I am designing now. But the insertion loss I achieve is poorer than the MAG of the transformer. So I'm wondering if there's a way to optimize the PA around the transformer to get the best possible insertion loss (i.e. close to the MAG), or vice versa. Perhaps I am not understanding something properly...
thanks,
Aaron
aaron_do
Reply #5 - Aug 1st, 2011, 6:38pm
after thinking on it more, I don't think MAG is very useful for transformer design because if I understand it correctly, it is not possible to achieve MAG for a lossy two-port passive device. You could argue that it is just a FOM of course...
cheers,
Aaron
rfcooltools.com
Reply #6 - Aug 2nd, 2011, 1:24pm
aaron_do,
If the xfmr is on chip then you can play around with the turns ratio, to get max available gain from your xfmer (provided your bandwidth is small enough) resonate either the primary or secondary or both to achieve the most optimum match. Also consider a narrow band impedance transformer instead of a broadband transformer this should be the lowest loss, again provided that you bandwidth is small enough.
http://rfcooltools.com
aaron_do
Reply #7 - Aug 2nd, 2011, 6:56pm
Hi rfcooltools.com,
when you say "max available gain", are you referring to the definition of Gmax with a simultaneous conjugate match at both ports? I don't know for sure, but I think this is not possible to achieve Gmax in a passive device when loss is taken into account. Take the simple case where the DUT is a series resistor. I cannot see any way to match this device at both ports using passive components. That's why I think using Gmax as an FOM for a XFMR is a bit arbitrary.
cheers,
Aaron
rfcooltools.com
Reply #8 - Aug 5th, 2011, 9:40am
Aaron_do,
For a broadband match I agree a simultaneous match cannot be achieved, but as I pointed out over a band limited range of frequencies it is possible to match both simultaneously.  Also I agree the FOM can be less than meaningful for all conditions.  Is your PA a narrow band or broadband?
inductioner
Reply #9 - Aug 7th, 2011, 5:44am
Hi Aaron,
I think Gmax is usually used for transformer characterization, or as one of passive device merits of figure. When using XFMR for design, T or Pi model can be more useful to gain more circuit insight.
I designed a few CMOS PAs with integrated or off-chip XFMR. I was pretty much following the old-time PA design methodology : Use load-pull technique to do all the followings : 1. Power match to maximize PA output power 2. PAE match to target at power-aided efficiency 3. For linear systems (especially OFDM ones) linear match is also one of the constraints to check AM-AM and AM-PM.
In so doing, I worked on load-pull analysis (after a few some basic checks on P1dB, AM-AM and AM-PM, stability, etc.) for PA core. excluding XFMR, which I consider as part of PA output matching netowork in the configuration I am figuring. The partition is arbitrary. I had included on-chip XFMR as part of PA core, the result was the same, as it should be. But the parasitics  of PA core can play a major role in matching optimization especially when dealing with > 5GHz operating frequency.
So, back to you question : I normally don't worry about transformer characteristic precisely from initial design phase; only the first order model parameters such as turn ratio, magnetically coupling coefficient k, rough L/C parasitic values and so on you will deal with. In the mean time, transformer can be designed to meet your electric and magnetic needs with the best achievable insertion loss (determined mainly by substrate rho, resistive loss, low magnetically coupling coefficient, etc.)
In final stage of design, surely we need to put everything together to see if the result is good.
Hope the above is useful to you.
cheers,
inductioner
aaron_do
Reply #10 - Aug 7th, 2011, 6:35pm
thanks a lot for both of your replies.
rfcooltools.com,
actually what I was saying is that for a passive lossy device, it is not possible to get a perfect match at even a single frequency (i.e. narrowband. No need to consider broadband). This to me is important because it tells me that Gmax doesn't have physical meaning for a transformer. As I said, for an example, try to do a two port conjugate match on a series resistor. I have discussed this with a colleague, and he has concluded that for a passive lossy device, a perfect match can only be achieved for an odd number of ports.
inductioner,
thanks for the great advice. I'm quite new to PA design, so I hadn't really thought of "linear match" to optimize AM-AM and AM-PM. I assume you mean to do a load-pull simulation to find the load which optimizes AM-AM and AM-PM. Apart from that, I think I'm using a pretty similar design methodology.
thanks,
Aaron
Gloria_evans
23306 Three Notch Rd Californi
Reply #11 - Sep 27th, 2011, 4:25am
Here is the method used by the rhombus industries must be useful for you.
Follow this link "http://www.rhombus-ind.com/app-note/fr-il.pdf"
aaron_do
Reply #12 - Sep 27th, 2011, 6:20pm
Hi Gloria,
thanks for the reply. However, I don't see how that schematic could work. The load side is shorted to ground, so how can there be a voltage to measure?
thanks,
Aaron
weber8722
Reply #13 - Nov 24th, 2011, 8:04am
aaron_do wrote on Aug 2nd, 2011, 6:56pm:
Hi rfcooltools.com,
cheers,
Aaron
Hi, for the series resistor Gmax would be just 0dB, but the impedances for load and generator would become infinite (not so special in a Smith chart Smiley). So Gmax is just one FOM, but not the most important one, in your application Gmax may not matter much, because you are limited to a certain range of impedances. Therefore available gain matters more.
Bye Stephan
