Jul 17th, 2024, 7:35am
receiver dynamicrange - input signal estimation (Read 1921 times)
paddu
Nov 27th, 2011, 12:47am
 Most of wireless receivers dynamic range varies from 60 - 90 dBm. Dynamic range is entireley controlled by programming the individiual gains of LNA, Mixer and VGA's.
My question is how to detect the input signal strength in order to have programmable gain settings so that ADC has the required dynamic range.
How the receiver identifies the input signal strength (across the dynamic range) to set the rx chain gain automatically so that ADC receives the required signal?
Thanks.
aaron_do
Re: receiver dynamicrange - input signal estimation
Reply #1 - Nov 28th, 2011, 5:16pm
try reading up on RSSI (Received Signal Strength Indication). For example, go to IEEExplore and search "CMOS RSSI".
regards,
Aaron
EDIT: I'm not sure exactly how its done, but I guess they can use the ADC saturation as a reference for the gain setting in a feedback loop. The gain setting itself is taken into account when calculating the signal strength. Maybe somebody else can give more details. Also check this link:
http://www.designers-guide.org/Forum/YaBB.pl?num=1242377069
Reply #2 - Nov 29th, 2011, 3:48pm
also research the topic of "log amps" or "logarithmic amplifiers" which get used in RSSI systems.
