Patrick,
Is there any reason you need to use Shooting Newton PSS analysis? The HB engine has also matured and is another option that may provide better performance. This will speed up the PSS portion of the analysis. Since it seems like you have an LC oscillator without a divider, you might also want to try the oscinit=linear option. When using the oscinit=linear, transient is not used for the either the initial conditions or for the PSS analysis. Don't forget to set tstab=0.
