Jul 17th, 2024, 9:36pm
How to do Verilog/VerilogA co-simulation , using cadence ams ? urgent (Read 6894 times)
dongzz201
China
Jun 30th, 2011, 7:19pm
How to do the ams simulation , using  verilog + verilogA ?
Now My top cell is verilog file, in which the analog sub-module is instantiated.
1. The analog sub-module is SPICE netlist.
   I can run the ams simulation.
   The amsd block is :
      include "./source/ana_cell.spi"  ( SPICE netlist file )
       amsd {
                  ie  vsup=1.8
                  portmap subckt=ana_cell
                  config cell=ana_cell use=spice
2.  The analog sub-module is verilogA file .
          My amsd block  is :
          ahdl_include "./source/ana_cell.va" ( VerilogA file )
          amsd {
                     ie  vsup=1.8
        Then the simulator always give me an error :
          " Could not determine discipline for xx.xx.xx "
       how to create the right amsd block ?
Urgent!
Re: How to do Verilog/VerilogA co-simulation , using cadence ams ? urgent
Reply #1 - Jul 1st, 2011, 6:21am
Hi donzz201,
I don't think that you define connect rules for your simulation model. I came across a similar problem in 2008. Please click the following link for details.
http://www.designers-guide.org/Forum/YaBB.pl?num=1230197093/2#2
Best Regards
Yawei
dongzz201
China
Reply #2 - Jul 3rd, 2011, 6:20pm
Thanks for your reply!
i am also confused after reading your comments.
I think , since using SPICE netlist, i can run ams correctly, the connect-rules should be already found.
I do not understand that the ams do not run after using the verilog-A files to replace the original SPICE netlist.
So the amsd block may not been correctly defined.
please give more ideas.
