dongzz201
China
Thanks for your reply! i am also confused after reading your comments. I think , since using SPICE netlist, i can run ams correctly, the connect-rules should be already found. I do not understand that the ams do not run after using the verilog-A files to replace the original SPICE netlist.
So the amsd block may not been correctly defined. please give more ideas.
