Jul 3rd, 2025, 2:24am
WARNING (ADE-6003) : ADE Cadence (Read 7832 times)
AnkurVerigy
Jul 04th, 2011, 4:37am
Hi All,
I get the following error message in the Candence Virtuoso when i am trying to simulate an RCX netlist ....
WARNING (ADE-6003): Terminal "IOUT", specified in the CDF termOrder, does not exist
\o            in the cell-view "aTEQUILA2v0" "alCSOURCEL2sw4v2" "schematic"
\o WARNING (ADE-6004): Mismatch was found between the terminals in the cellView and those on the
\o            termOrder property on the CDF. Because of the mismatch, the CDF termOrder will
\o            be ignored. The terminals in the cellView will be netlisted in the alphabetical
\o            order of their names. Eliminate the mismatch if you want the CDF termOrder
\o            property to be used for netlisting.
\o            To edit CDF of a cell,
\o            i) Open CIW->Tools->CDF->Edit.
\o            ii) Select Library Name & Cell Name.
\o            iii) Click on the Edit button in the simulation information section of the
\o                 Edit CDF window.
Can anyone will let me know what direction should i look into ?
Ankur
Re: WARNING (ADE-6003) : ADE Cadence
Reply #1 - Aug 13th, 2011, 6:26pm
I don't know what you did.
If you want to remove the warning message, please edit the term order following that steps, to edit CDR of a cell.
Yawei
