Sep 2nd, 2024, 7:16am
Maneatis partial-swing delay cell. (Read 6312 times)
raja.cedt
Jul 18th, 2011, 12:24am
hello,
i have doubt regarding this delay cell. I know that one transistor in this pmos load has to be in triode region, because then only it will linear V-I characteristics.  But if you see the replica bias i think because of the bias both both transistors in saturation region. Can any one please clarify this?
Thanks.
Re: Maneatis partial-swing delay cell.
Reply #1 - Jul 18th, 2011, 2:29pm
I have used the Maneatis delay cell in ring oscillators many times, but I did a redesign of the bias system
neoflash
Mixed-Signal
Designer
Reply #2 - Sep 6th, 2011, 5:37pm
loose-electron wrote on Jul 18th, 2011, 2:29pm:
one thing I noticed is that anything I touched in its design will trigger a chain effect. The only exception is the charge pump.
rajkumar palwai
Sunnyvale, California
Reply #3 - Sep 29th, 2011, 10:18am
Hi Raja,
You can understand maneatis cell in terms of current. Please see the attached figure. The figure plots the different current components of a maneatis cell w.r.to voltage across it.
The currnet through the  current source transistor  is shown in red color. The current thru diode connected is shown in blue curve. The average current (Itotal*0.5) is shown in black color. I have shown Itotal*0.5 current rather than Itotal, since it shows nicely how averaging is happening in the cell. Current will become some kind of linear across the voltage range and hence the cell acts as a linear resistor.
rajkumar palwai
Reply #4 - Sep 29th, 2011, 10:20am
Forgot to add the figure
rajkumar palwai
Reply #5 - Sep 29th, 2011, 10:23am
Hence the cell acts as a linear resistor only till the voltage where the cross over happens between two currents.
