Sep 2nd, 2024, 5:16am
Pages: 1 2
is this circuit have overal -ve feedback? (Read 2480 times)
raja.cedt
Aug 17th, 2011, 1:02am
hello all,
Can any one please tell me is this circuit have -ve feedback around the opamp? i feel gain from the M1,M2 stack will be more than M3,M4 stack, so in this case +ve feedback is more dominant than -ve FB.
Thanks.
Re: is this circuit have overal -ve feedback?
Reply #1 - Aug 17th, 2011, 3:35pm
I am having a hard time understanding your question. Can you re-ask the question, this time being careful with your English. Also, please define what you mean by +ve feedback and -ve feedback.
wave
Reply #2 - Aug 17th, 2011, 5:31pm
This particular circuit looks odd, but I've seen similar discussions on Bias circuits.  (either a delta VBE bipolar loop, or delta Vgs MOS loop).
Often a amplifier is used to control the PMOS current mirrors.
(as drawn, I'm not sure the Amp is controlling the circuit much on the Nmos cascodes).
Basically M3 is lower impedance than the M2 side.
This will influence the gain, and the "polarity" of the op-amp hook up.
It's not the most direct circuit to analyze, so I'm assuming/guessing that the question --- is it Positive or Neg. Feedback?
Raj - make sense?
Cool
~Wave
Lex
Eindhoven, Holland
Reply #3 - Aug 18th, 2011, 12:22am
Well, what you could do: connect a voltage source to the cascode, and sweep it. You observe what happens with the voltage at the top node on the left and on the right. Having these graphs, you can draw the conclusion.
raja.cedt
Reply #4 - Aug 18th, 2011, 12:27am
hello guys,
ya you are correct for this kind of circuit it's hard to say which one is +ve and which one is -ve. But so as to make operating point stable we ned to ensure if any distrubance occur any where finally loop should restore previous operating point. In that sence i applied some signal at the o/p but it's keep on diverging rather converge.
other wise...for get about all the discussion above and just tell me wether opamps polarity is correct or not.
Thanks.
buddypoor
Bremen, Germany
Reply #5 - Aug 18th, 2011, 12:49am
raja.cedt wrote on Aug 18th, 2011, 12:27am:
Thanks.
Can be answered (with regard to a stable quiescent point) only if we know what will be connected to both opamp inputs - in addition to the shown parts (to the left and to the right, since you have drawn a line).
raja.cedt
Reply #6 - Aug 18th, 2011, 12:59am
hello buddy poor,
nothing is there, shown is the total circuit.
buddypoor
Bremen, Germany
Reply #7 - Aug 18th, 2011, 6:41am
raja.cedt wrote on Aug 18th, 2011, 12:59am:
hello buddy poor,
In this case, can you explain why - in your view - "gain from the M1,M2 stack will be more than M3,M4 stack"?
raja.cedt
Reply #8 - Aug 18th, 2011, 6:53am
hello buddypoor,
please find the attached fig. So correct me if am wrong any where.
Thanks.
buddypoor
Bremen, Germany
Reply #9 - Aug 18th, 2011, 9:50am
One comment: opening the loop at the opamp output means that both gates are still wired together. So you have no choice to inject the test signal into the gates of  M1 or M4.
One question: What is your reference node for the gain calculation?
For the loop gain the feedback signal at the opamp inputs are relevant.
nrk1
Reply #10 - Aug 19th, 2011, 7:16am
raja.cedt,
There is no (significant) feedback around the opamp. Break the loop at the opamp output, inject a test signal to the gates of M1,4, and see what returns at the opamp output. Assuming transistors with gds=0 and current sources with a finite Rout, the test signal at the gates of M1,4 creates a current of 2/gm*Vtest in M4,3 which is also mirrored to M2. M1 acts as a cascode. So the difference voltage across the opamp inputs is zero. A non-zero gds modifies this calculation only slightly. Bottomline, don't use this circuit.
raja.cedt
Reply #11 - Aug 24th, 2011, 11:00am
hello nrk1,
thanks for your reply. Ya due to test source you will get gm/2*vtest current in both legs, so due to this voltage at the drain of m4 will be roughly (2r0)*(gm/2), but drain of the m1 will like m/2(gm*ro)*ro. so you will have more swing at drain m1. is any thing wrong in my explanation.
i saw this ckt in this paper "Transient Charge Feedforward Driver for High-Speed Current-Mode Data Driving in Active-Matrix
OLED Displays".
Thanks.
Rakesh
Reply #12 - Aug 24th, 2011, 11:31am
 Assume that M4, M1 gds to be zero and M2 and M3 has finite gds.
Break the loop at gate of M4 and M1.
the current produced in transistors will be (gm/2)Vtest+(gds/2)Vtest on the left side and (gm/2)Vtest + gm/(1+gm/gds)Vtest on the right side.
Both sides transistors M1 and M4 acts like a cascode transistor with degeneracy 1/gm and 1/gds.
Now (gm/2)Vtest is common to both sides.
Since we have at the top ideal current sources
the extra current should flow into the out put impedances at the drains of M4 and M1.
The voltage developed at the +ve terminal of opamp will be
(1/gds) (gm/2 +gds/2)Vtest.
The voltage developed on the negative terminal will be
(gm/2 + gm/(1+gm/gds))(gm/gds^2)Vtest
The difference at the input of the opamp is approximately
gm/2(1/gds -gm/gds^2)Vtest + (0.5-gm/gds)Vtest
Assuming gm/gds >>>1
we have
difference as
-gm/2(gm/gds^2)Vtest-(gm/gds)Vtest
if the gain of the opamp id A
then at the output of opamp we have a loop gain whcih is negative  and high due to negative feedback as
-gm/2(gm/gds^2)A-(gm/gds)A
So i think the signs on the opamp is correct
Correct me if i am wrong
nrk1
Reply #13 - Aug 24th, 2011, 9:27pm
From your earlier post "... from M1,2 stack, the gain is ~ (gmro)^2 ..." is wrong. The gain from gate of M1 is ~ 0
If you are referring to Fig. 3 of the paper you mentioned, there is a diode connected transistor from the right branch to ground and a current source  from the left. Clearly the gain to the opamp's + sign is more. (buddypoor had earlier asked what else is connected to the circuit). In that case there is no ambiguity.
raja.cedt
Reply #14 - Sep 1st, 2011, 3:36am
hello nrk1,
thanks for your note. ya i forgot this. But from erlier post gain from gate of m1 is zero but one thing is m2 gate also moves due to m4,m3, correct me if am wrong.
Thanks.
Pages: 1 2
