If you had run noise analysis in ADE, the input referred noise power spectral density is there.
Then integrate the power spectral density from 1 Hz to 100 Hz, you get the total input referred r.m.s noise voltage (1 Hz - 100 Hz)
At last, I don't know what is acceptable range. You should ask your customer if you have, otherwise ask who is in charge of the project.
Yawei
