Jul 17th, 2024, 11:44am
Measuring INPUT impedance of the Passive Switching Mixer (Read 3367 times)
Ricky Chen
Jul 20th, 2011, 11:23am
Hi All,
I want to plot the input impedance ( in RF Port side) of a passive switching Mixer [2-Phase i.e. 2- 180 degree out of phase non-over lapping LOs with rise and fall time of 1 fs & Two switches Loaded with   Resistors of  50 Ohm at the IF ports] with respect to Frequency.
LO frequency was kept 1 GHz and the RF input frequency is swept from 0 to 5 GHz. The RF port impedance is kept at 50 ohm. Also I used analogLib delay element to generate 180 degree out-of pahse 2nd LO.
From theory I know this input impeadnce at the RF port will be a Frequency translated version of the IF side Impedance. But since I am using simple resistor at the IF side the RF side impedance will be the same resistor i.e 50 Ohm
I did PSS and PSP analysis and then I plotted the S11 but I got 0dB across  the frequency instead of getting a very large -ve value !!
Can anybody please tell me Where I am going wrong in doing the simulation ?
I have attached the circuit schematic.
My Netlist is as Below:--
// Library name: PASSIVE_MIXER
// Cell name: IN_IMPEDANCE
// View name: schematic
V0 (net7 0) vsource type=pulse pacmag=1 pacphase=0 val0=1 val1=0 period=1n \
       delay=0 rise=1f fall=1f width=500.0p
PORT0 (net1 0) port r=50 num=1 type=sine freq=frf dbm=prf fundname="rf"
DELAY0 (net033 0 net7 0) delay td=500.0p gain=1.0
R1 (IF_N 0) resistor r=50
R0 (IF_P 0) resistor r=50
SW1 (IF_N net1 0 net033) relay vt1=0 vt2=1 ropen=1T rclosed=1.0
SW2 (IF_P net1 0 net7) relay vt1=0 vt2=1 ropen=1T rclosed=1.0
   digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
   sensfile="../psf/sens.output" checklimitdest=psf
pss  pss  fund=500M  harms=51  errpreset=moderate  annotate=status
psp  psp  sweeptype=absolute  start=0  stop=5G  step=100M
+    portharmsvec=[0]  ports=[PORT0]  donoise=no  annotate=status
Larry_80
Re: Measuring INPUT impedance of the Passive Switching Mixer
Reply #1 - Jul 20th, 2011, 8:46pm
From your schematic, your circuit is terminated in 50 ohms load, so assuming you are using ideal switches, your s11 should be a large negative value in dB i.e perfectly or near perfect match. The only thing i can think of is maybe you are doing the measurement when the switch is off (OPEN CIRCUIT), thus u are observing a 0dB S11 value! I am not too sure, but this is what i think might be wrong!
Ricky Chen
Reply #2 - Jul 21st, 2011, 2:19am
Your reason may be valid but why the switch will be always open ??
RFICDUDE
Reply #3 - Jul 21st, 2011, 3:30am
Before debugging the PSS PSP result, you should run a transient simulation where the input signal is a sinusoidal signal at some offset to the LO pulse frequency. Do this just to make sure the switches are actually switching properly with the LO pulses.
