Aug 3rd, 2024, 9:29pm
How to add .lib to Cadence as like Hspice? (Read 979 times)
newic
Aug 10th, 2011, 11:35pm
how could cadence ADE to have .lib function as in the hspice? I know cadence can only include the file, but not choosing the variable in .lib (eg: term_ss in this case)
in hspice, users can make lib setting easily as below:
in the spice deck:
.lib 'my_setting.lib'  term_ss
content in my_setting.txt
.lib term_ss
vvar   var1 0  0
.endl
.lib term_ff
vvar var1 0  vcc
endl
Re: How to add .lib to Cadence as like Hspice?
Reply #1 - Aug 13th, 2011, 6:30pm
include "/process/smic_5.0/smic18/smic18mmrf1833.c.1/smic18mmrf/../models/spectre/ms018_
v1p9_spe.lib" section=tt
v1p9_spe.lib" section=bjt_tt
v1p9_spe.lib" section=res_tt
v1p9_spe.lib" section=mom_tt
v1p9_spe.lib" section=var_tt
newic
Reply #2 - Aug 14th, 2011, 5:23pm
the .lib is used for param setting instead of library setting. I know how to set library seting in ADE & Hspice.
I want to use .lib to choose param ( a group of setting usually)
Reply #3 - Aug 14th, 2011, 6:01pm
Don't forget you have already define a group of parameter in library section. That is a part of a library.
Usually some parameters are defined in model file. So you can choose a group of parameter with library setup.
