lhlbluesky_lhl
i use hercules + star-RC to extract the layout netlist, but the ideal netlist generated by star-RC has some problems:
for example, i have one subckt AAA, it has three ports: IN OUT BIAS, but the translated ideal netlist has more ports as follows:
.subckt AAA IN OUT BIAS ln_N_27 ln_N_31 ln_N_33 ln_N_35 ************* .ends AAA
******* XI2 IN1 OUT1 BIAS1 GNDA1 GNDA1 GNDA1 GNDA1 AAA
the additional ports ln_N_27, ln_N_31, ln_N_33, ln_N_35 don't exist in my layout at all, and all the additional ports connect to GNDA when instancing. such subckt which has additional ports(ln_N_*) is more than one. i want to know, why are the additional ports (ln_N_*) generated in netlist? is it caused by nettran? and how to solve this problem?
besides, can anyone use synopsys tools XA for simulation? in XA's BA(back annotation) flow, first, i use hercules + starrc to extract the ideal netlist (ideal.sp) and parasitic included netlist (top.spf), then i use BA flow for layout post-simulation. but i have a question here, in the ideal netlist, there is many additional nets (ln_N_*) which is not used in my layout at all as above mentioned. another aspect, the BA back annotation rate (back annotation without error) is not 100%, there are many nets not back annotated correctly, and these nets exist in resistor, for example, i have a big resistor (l=30u w=1u) which has three segments: the ideal netlist is: XRR1 OUT OUTN1 rpmpoly2t l=10u w=1u XRR2 OUTN1 OUTN2 rpmpoly2t l=10u w=1u XRR3 OUTN2 OUTN rpmpoly2t l=10u w=1u but the spf netlist is: XRR1 XI23/XRR1:A XI23/XRR1:B rpmpoly2t l=10u w=1u XRR2 XI23/XRR2:A XI23/XRR2:B rpmpoly2t l=10u w=1u XRR3 XI23/XRR3:A XI23/XRR3:B rpmpoly2t l=10u w=1u
and these nets (XI23/XRR1:A XI23/XRR1:B XI23/XRR2:A XI23/XRR2:B XI23/XRR3:A XI23/XRR3:B) cannot be correctly back annotated, what is the reason? can anyone has the same experience before?
thanks all for reply in advance, thanks.
