Sep 1st, 2024, 5:17am
Output imepedance (Read 2851 times)
Rakesh
Output imepedance
Aug 24th, 2011, 11:39am
   I was working on increasing the linearity of the transconductor.
I get a good linearity if i short the output and measure the current.
However if i allow a swing of say peak to peak 400mV on the output my linearity goes down to 60dB .
My output impedance is 400k. Can u suggest me techniques or ways of increasing the output impedance apart from cascoding.
Rakesh
harpoon
Hampshire
Re: Output imepedance
Reply #1 - Aug 24th, 2011, 1:17pm
Make L bigger ... Or use feedback, I'll have to think about the circuit.
Reply #2 - Aug 26th, 2011, 10:25am
gmC filter transconductor?
Prior suggestions are good.
Also - Increase the static bias current of the device so the signal is a smaller part of the total current.
Also differential pair structures can be replaced with multi-tanh structures as gets used in LNA front ends.
Vladislav D
The Netherlands
Reply #3 - Aug 27th, 2011, 4:49am
loose-electron wrote on Aug 26th, 2011, 10:25am:
To increase current through the devices in order to increase output impedance? Sounds controversial.... Undecided
Reply #4 - Aug 28th, 2011, 12:17pm
He is having problems with linearity vs. output impedance.
Thus the suggestion on how to improve linearity.
If we know the application a bit more may be able to make better suggestions, I am guessing a gmC filter (4 transconductors per biquad) , but it has not been stated.
