Aug 16th, 2024, 11:06pm
Sample rate conversion (Read 5168 times)
SARAM
Sep 07th, 2011, 11:51pm
I want to write code for simulating interpolator.
I have two clock domain  CLK_low , CLK_high.
I want to increase sample rate by this ratio CLk_h/CLK_l.
I write code below and feed it with ramp but in some place it did not work correctly.
please help Cry
Clk_h=150 MHz;
CLK_l=61.44 MHz;
this program use linear interpolation y=(1-n)*Xn-1+n*Xn
that n is 0<n<1;
module SRC (in,out,CLK_l,CLK_h);
parameter integer OSR_1 = floor((1/(150/61.44))*pow(2,9));
     parameter integer scale = pow(2,9);
     input  in,CLK_l,CLK_h;
     output out;
     wreal  in,out;
     integer   fraq_cnt = 0;
     real   xn,xn_1,y_lin,frq,frq1;
     always @(posedge CLK_h )      begin
                 fraq_cnt = fraq_cnt + OSR_1;
                 frq1     = (fraq_cnt % scale);
                 frq      = frq1/scale;
                 y_lin    =  (1-(frq)) * xn_1 + (frq) * xn;
     always @(posedge CLK_l ) begin
                 xn_1   = xn;
                 xn     = in;
assign      out = y_lin;
boe
Re: Sample rate conversion
Reply #1 - Sep 9th, 2011, 4:23am
SARAM,
Quote:
... but in some place it did not work correctly.
Please be more specific. Without more information we can only guess.
B O E
SARAM
Reply #2 - Sep 14th, 2011, 3:43am
The previous code was written for linear interpolation.
This one was written for Zero order hold. and the same clock frequency as above.
    output out;
    wreal  in,out;
    real   xn,xn_1,y_zoh;
               y_zoh = xn_1;
                xn_1   = xn;
                xn     = in;
How can I make sure that in every rising edge of higher clk system take data and do the ZOH operation?
I dont see that there are some point at rising edge of Clk_h. and also the input is a linear ramp but the output is not.
Would you please help me
Amir
boe
Reply #3 - Sep 14th, 2011, 12:40pm
SARAM,
please show input and output trace with sample&hold, not interpolated. Discrete values of output would also be interesting.
I suspect an display issue.
B O E.
SARAM
Reply #4 - Sep 14th, 2011, 11:41pm
Thanks B O E
Attached, you can see what you asked.
I just increase the CLK_h by factor of 2 in this figure.
if this is display problem how can i make sure the number of samples at the output were increased? I can not see the symbol in between of two low rate clk that sampled with high rate.
boe
Reply #5 - Sep 15th, 2011, 3:54am
SARAM,
This plot seems OK to me. Note that this is digital simulation; you don't get time points unless the value changes.
B O E
SARAM
Reply #6 - Sep 15th, 2011, 4:44am
Hi BOE,
You mean that by this way I increased data samples at the output in ZOH manner.
another question is that how can i solve the problem with linear interpolation. (first code i have written at my first post). what can i do when two clock are async.
how can i implement linear interpolation? is there another way to implement with two async clock?
boe
Reply #7 - Sep 15th, 2011, 8:30am
Hi SARAM,
I suggest you store time ($realtime) of last slow edge and check that frq/frq1 are correct. Look for two things:
  • correct period (e.g. due to rounding error on OSR_1), and
  • no offset between frq/frq1 and relative position to clocks ("offset").
B O E
