Jul 18th, 2024, 1:27am
VHDL-AMS VBIC model? (Read 3549 times)
the_pd
Sep 16th, 2011, 4:09pm
I am in need of a VHDL-AMS VBIC implementation. So far, it looks like Verilog-A is the language of choice, however. Anyone know where I could find a VBIC model in VHDL-AMS? Thanks!
Re: VHDL-AMS VBIC model?
Reply #1 - Sep 18th, 2011, 1:45pm
Strange mix of platfoms.
Verilog A or AMS is generally used for functional level models, not transistor level models.
If you need to simulate at the transistor level, perhaps you should consider using a EDA platform with a Spice-Spectre type of simulator?
Reply #2 - Sep 19th, 2011, 8:20am
loose-electron wrote on Sep 18th, 2011, 1:45pm:
Jerry - You've missed the revolution in transistor-level compact modeling: almost all the latest transistor models (PSP, BSIMSOI, VBIC, Mextram, Hicum, ... and soon BSIM6) are written/developed in Verilog-A.  Spectre, HSpice, Eldo, etc. all have Verilog-A compilers.  The users can then modify the source code to add new equations / model features.
That said, it is Verilog-A; I can't recall ever seeing a compact model written in VHDL-AMS, other than maybe a basic diode as an example.  Verilog-AMS added a bunch of features to the language in LRM 2.2 to make compact modeling easier, and that's where the developers have gone.
