May 4th, 2024, 11:30pm
plotting calculator functions on PSS data? (Read 1128 times)
SoliS
Sep 28th, 2011, 7:09am
I am new to the PSS simulator, but I've read the manual. It seems as though there is a way to add a design parameter sweep into the PSS analysis, which I have working.
What I want is a plot of THD as I sweep the magnitude of the input voltage of a buffer stage. I know how to work the THD function in the calculator, but I have a disconnect between how to get the transient waveform data from the PSS sweep, and how to use the calculator function on it and then plot.
Can anybody help?
