Jul 17th, 2024, 7:19am
Stabilization Methods for Common-Base (CB) and Common-Collector (CC) at RF Fre (Read 4642 times)
jianke
Oct 04th, 2011, 8:53pm
Recently I met an interesting question for RF amplifier design. As we know, by adding a series inductor at Emitter, we can increase the stability of a BJT Common-Emitter (CE) amplifier. When it comes to a Common-Base (CB) or a Common-Collector (CC) amplifier, what should we do to increase its stability?
My objective is at 2.14GHz: (1) the CB amplifier works as a “current follower” (voltage amplification); (2) the CC amplifier works as a “voltage follower” (current amplification).
What I have tried for a CB amplifier is:
(1) Adding a series resistor at output, but the S parameters becomes really bad, typically S11 and S22. Also, the voltage gain decreases much.
(2) Using the ADS optimization tool to improve stability and S-parameters performance, but the results are not good. Typically the CB amplifier cannot work as a “current follower”. Also, the voltage gain decreases much.
The attachments are ADS simulations files and some simulations results. I hope they would be useful for your analysis. Thanks!
jianke
Re: Stabilization Methods for Common-Base (CB) and Common-Collector (CC) at RF Fre
Reply #1 - Oct 7th, 2011, 7:10pm
Doesn't anyone have an idea or any comments?
My goal is to improve the stability to avoid oscillation at 2.14GHz.
So, what should I do for Common-Base (CB) or a Common-Collector (CC) configuration?
Waiting for your suggestion. Best Regards!
purplewolf
Reply #2 - Oct 9th, 2011, 3:28pm
for common drain ( or common collector) amplifier put a series RC circuit in parallel with the the gate of amplifier .
weber8722
Reply #3 - Nov 17th, 2011, 8:33am
These things often help:
CC: series R at base or emitter
CE: series R at base or at collector
CB: series R at base
This is often bad:
CC: C at emitter
However, there is also some try-and-error. For instance, a cascode should be quite stable, but often its not due to large gain. Or in CE a L at emitter helps, because it reduces the gain, but also element self-resonances can destroy good performance and stability a lot. Undecided
rfcooltools.com
Reply #4 - Nov 17th, 2011, 12:04pm
jianke,
If you study some of the older VCO architectures you can get an insight into what to avoid.
Common base amplifier Colpits oscilator comes to mind.
Zbe is base emittor parasitic capacitor 1/(j w Cpi).
Ze  is parasitic capacitance to ground for example 1/(j w Cpara).
Impedance looking into the base  Zin= Zbe + Ze + Zbe*Ze*gm
Notice that Zbe*Ze*gm will be negative and real.  This is why the colpits works, but not what you want .  Positive resistance in series with the base, if greater than the negative should negate this oscillation mechanism.
http://rfcooltools.com
