Jul 17th, 2024, 7:17am
Package Inductance for 10 GHz range operation (Read 5386 times)
Ricky Chen
Oct 05th, 2011, 8:13am
Dear friends,
Can anybody tell the best package available for 10 GHz RF signal operation ?
The lowest inductance is desirable. Bondwire inductance can be reduced for smaller package but what about LEAD inductance ?
What PCB material should be used and what is the constraints on PCB trace for proper operation at 10 GHz?
rfcooltools.com
Re: Package Inductance for 10 GHz range operation
Reply #1 - Oct 10th, 2011, 11:10pm
Ricky-chen,
if price is no option when a flipped chip on rodger4003 substrate will probably be pretty good.
More practically what kind of signals are these 10GHz are they tones or are they broad band up to 10GHz.  The reason I inquire is that the answer to this will determine if a low impedance at high frequency is needed or if the impedance at high frequency of a bondwire can be resonated or transformed into something more benign.
http://rfcooltools.com
Ricky Chen
Reply #2 - Oct 11th, 2011, 6:27am
Thanks for your reply
It is Broad Band. I think tuning is not perhaps an option.
By the way what is the cost of rodger4003 substrate ?
What it actually helps ?
-Ricky
rfcooltools.com
Reply #3 - Oct 28th, 2011, 10:09pm
Ricky Chen,
rogers is about 5 to 10 time more expensive than fr4.
Its controlled under tighter process parameters more predictable t-lines and even strip-line filters epsilonR is different and is stable over temp.  You can make do with fr4 depending on your application.
Reply #4 - Oct 29th, 2011, 11:57am
QFN packages are commonly used up to 5GHz, and perhaps are viable to 10GHz.
Need to look at the package model and determine the reactive elements.
chip on board with a specialty dielectric are another possible but if you want a typical chip in package on pcb i would look at the QFN
Ricky Chen
Reply #5 - Nov 16th, 2011, 5:19pm
Thanks loose-electron,
Can you tell us the cost of Chip on board. I mean how much costlier it will be than the FR4 PCB.
I think one can also mount all discrete components on  Chip on board.
Do you think FR4 PCB with QFN package will work well till 5 GHz.
Reply #6 - Nov 16th, 2011, 9:39pm
keep the traces short and include the board parasitics in your model and hit the simulate button!
Ricky Chen
Reply #7 - Nov 16th, 2011, 9:44pm
loose-electron wrote on Nov 16th, 2011, 9:39pm:
Simulate button for what simulation ?
Can you mention something more about Chip on Board if u have experienced using that
Reply #8 - Nov 18th, 2011, 9:02am
the parasitics of your board, the traces on the board, the RLC of the package can all be included into your simulation to determine if the methods proposed will work at the desired frequency.
You need to look up the coefficients of capacitance and inductance for  the proposed PCB material and estimate those components in a simulation.
