Jul 17th, 2024, 5:27pm
Multiple cadence "STB" analysis (or any) in one run (Read 5089 times)
nano_RF
madison
Oct 07th, 2011, 3:38pm
Is it possible to run two "Stability" analysis in cadence? This is to check the stability of two non-related loop in one run. So essentially "STB" probe needs to be different and so the need to run two stability analysis.
Actually I am doing big corner simulation with various analysis selected and was hoping if there is a way to get the stability of two loop in one run. Or else i have to do another corner run just to check the stability of the other loop.
Thanks in advance..
Re: Multiple cadence "STB" analysis (or any) in one run
Reply #1 - Oct 7th, 2011, 11:16pm
Do you run corner analysis with Analog Design Environment? In ADE, the name for stb analysis is stb, and tran for tran analysis, ac for ac analysis. So the user cannot set more than one stb analysis if you work with ADE.  However, you'd better try Ocean or other scrip language.
--Yawei
rfidea
Europe
Reply #2 - Oct 8th, 2011, 6:53am
Which software are you using? I suppose you are using Analog Artist or Virtuoso from CDS.
If you are using version IC5.1.41 or older you are stuck with running one stb analysis per spectre run. If you are using IC6.1 you still have the same limitation when using the ADE tool. But if you use ADEXL you can define several Tests with different stb analysis in each Test.
nano_RF
madison
Reply #3 - Oct 10th, 2011, 8:01am
Thanks ywguo and RFidea.
Yes, I am using corner tools off ADE and yes it is 5.1.41 cadence version. So, I guess pretty much stuck with it.
I will play with ocean scripting to do sort of parametric run and dump the old result on to a file.
