Sep 3rd, 2024, 3:20am
unity gain bw of a push pull aplifier (Read 887 times)
mixed_signal
Oct 19th, 2011, 1:32am
I want to find the ugb of a push pull aplifier. What is the simplest method to do it? Is it gm/cL? In allen Holdberg the open loop gain and 3db pole is calculated. What if I multiply both and get UGB?
HdrChopper
Re: unity gain bw of a push pull aplifier
Reply #1 - Oct 19th, 2011, 5:28am
why not?
If your non-dominant poles are higher than your GBW then your calculation will be correct.
Best
Tosei
Keep it simple
mixed_signal
Reply #2 - Oct 19th, 2011, 11:48am
Thank you thechopper. But what about gm/cL? Will it work?
Another method is gm/C1 where C1 is responsible for dominant pole. What about this method? Smiley
raja.cedt
Reply #3 - Oct 20th, 2011, 12:28am
both are correct, UGB=gm/(c), where c is the cap which is responcilbe for dominate pole, so take a amp which has dominate pole at at load so UGB=gm/cl, or consider miller compensated opamp there cc is responcible for dominate pole, so ugb=gm/(cc)
raj.
mixed_signal
Reply #4 - Oct 20th, 2011, 11:26am
Thank you raj!
