Sep 3rd, 2024, 1:21am
How can I give variables as parameter to a module (Read 1562 times)
aistudy
Oct 19th, 2011, 1:55am
how can I give variables as parameter to a Verilog-A module?
I wrote the module Resistor in Verilog-A with parameter Noise and value of resistance.
module Resistor(p,n);
electrical p,n;
parameter real R=1.0 from [0:inf];
parameter integer Noise = 1 from [0:1];
I can pass numbers direktly as parameter:
Resistor #(.R(4)) r_gate(G, g);
But I can't pass any calculated value or a value which is a parameter or variable.
I would like to pass the Variable "R_g", which will be calculated in following sample:
WF=UGW/1000;
WZ=WF/2;
Wtot=WF;
R_g=rg*WZ;
I'm becoming the following error message from Agilent ADS:
"Invalid (non-static) initialization for parameter R"
Sometimes ADS gives non error message but the result of the DC-simulation are not practicable.
How I solve this problem?
Thanks a lot!
boe
Re: How can I give variables as parameter to a module
Reply #1 - Oct 19th, 2011, 3:45am
Hi Aistudy,
aistudy wrote on Oct 19th, 2011, 1:55am:
WF=UGW/1000;
WZ=WF/2;
Wtot=WF;
R_g=rg*WZ;
Instance parameters must be constants. E.g. Code:
localparam real rg = <val>,
    UGW = <val>,
    WF=UGW/1000,
    WZ=WF/2,
    Wtot=WF,
    R_g=rg*WZ;
Resistor #(.R(R_g)) r_gate(G, g);
should work.
If you want to change the value dynamically, you need to declare R as dynamicparam (if ADS supports this).
- B O E
« Last Edit: Oct 19th, 2011, 5:31am by boe »
aistudy
Reply #2 - Oct 19th, 2011, 5:20am
the declaration as localparam solved my problem.
Thanks a lot.
