Apr 26th, 2024, 6:04pm
JEE not matching with Pnoise Time-domain (strobed) analysis (Read 7932 times)
rajkumar palwai
Sunnyvale, California
Oct 19th, 2011, 9:50am
For driven circuits like dividers, we see JEE as the jitter metric. In spectre Pnoise analysis we can see the JEE directly using the "Jitter" analysis. Ideally this number should be equal to the (total sampled rms noise voltage/ (dv/dt)). I have calculated the total sampled noise using the Pnoise "Time-domain' (also referred as strobed noise analysis) and then tried to match the number with the JEE number. But they are not coming out same.
Please suggest me if am doing anything wrong in the calculations.
rajkumar
msr
Re: JEE not matching with Pnoise Time-domain (strobed) analysis
Reply #1 - Mar 25th, 2012, 12:33am
1) Formulae Jee = Vn-rms-dsb / (dv/dt at threshold crossing)
2) Vn-rms-dsb :
Spectre takes Noise BW = (Maximum Sidebands + 0.5) * F-clk. Vn-rms-dsb = SQRT( (Maximum Sidebands + 0.5) * F-clk ) * PSD-dsb
For example PSD-dsb = SQRT(4KTR) for a resistor.
But if the circuit band-width is less than the noise bandwidth then circuit bandwidth should be considered in Vn-rms calculations.
3) Calculate dv/dt in a very small voltage range around threshold at output.
Srinivas
