Sep 4th, 2024, 7:19pm
double guard-ring in driver & pre-driver (Read 7381 times)
newic
Oct 19th, 2011, 10:49pm
normally double guard-ring is added in the IO driver which has large current. How about pre-driver? Should guard-ring be added into the pre-driver. Predriver consume average current about 1.5mA.
raja.cedt
Re: double guard-ring in driver & pre-driver
Reply #1 - Oct 20th, 2011, 12:25am
what do you mean by double ring driver? is it h-bridge driver?
newic
Reply #2 - Oct 20th, 2011, 12:49am
inverter based voltage driver which is very noisy as compared to current driver.
double guard-ring is added to protect latch up issue
raja.cedt
Reply #3 - Oct 20th, 2011, 12:54am
so double gaurd is layout rite, so no need to care from ckt point of view?  So your's is voltage mode driver, so pre-drivers also kind of inverter based sturctre. To be frank i didn't understand the question. Because you are telling pre-driver consumes 1.5ma, and again you are asking wht about pre-driver...!!
Raj.
newic
Reply #4 - Oct 20th, 2011, 1:04am
question: "Should guard-ring be added into the pre-driver." which this pre-drive consume about 1.5mA
Reply #5 - Oct 21st, 2011, 5:58am
explicitly define your circuit
explicitly define what the circuit is supposed to do
explicitly define your layout
explicitly define your voltages, currents frequency
ask the question
without the above information its
impossible to answer the question
vp1953
Reply #6 - Oct 22nd, 2011, 9:54am
Hi Newic,
It probably does not hurt to have a double guard ring around the pre-driver. Aside from latch up prevention, it also helps to keep substrate currents confined to the local area, a factor that is of importance if the IO driver is sourcing large currents. 1.5mA does not seem like a huge current but if there are VCO's, bias generators etc in close proximity, having a double guard ring around the predriver would be helpful.
chaojixin
Shanghai
Reply #7 - Nov 6th, 2011, 6:25pm
newic wrote on Oct 20th, 2011, 12:49am:
Hi, may I ask how to determine the width of guard-ring to prevent the latch-up? how to do the calculation, and what tools is needed?
thanks!
View Profile chaojixin chaojixin 278916917   IP Logged
Reply #8 - Nov 7th, 2011, 1:08pm
foundry will have physical design rules for latch-up
These are minimum.
Suggest that substrate grounds and N-well rings be connected back to metal ground-power bias connection as much as possible.
chaojixin
Shanghai
Reply #9 - Nov 9th, 2011, 4:55pm
thank you very much!
