Sep 17th, 2024, 6:14pm
How to import an abstract LEF of a memory IP into Virtuoso (Read 5213 times)
orient
Oct 21st, 2011, 1:16am
Hi there,
I am designing an ASIC that uses a memory IP from my fab. The design is a mixed-signal chip, but I use the digital-on-top workflow, so most of the chip finishing is done on Encounter. However, I still need to fine tune the layout in Virtuoso.
Here's is the problem: in virtuoso, I don't have the layout view for the memory block (not even the abstraction layers, e.g. metals, blockages). Is it possible to import an abstract LEF cell into Virtuoso IC 5.10.41?
I would like to perform some visual inspections on virtuoso around the memory block, before tape-out.
Thanks.
C.
boe
Re: How to import an abstract LEF of a memory IP into Virtuoso
Reply #1 - Oct 21st, 2011, 1:23am
Hi Orient,
Is File -> Import -> LEF (in the icfb) what you are looking for?
- B O E
orient
Reply #2 - Oct 21st, 2011, 1:45am
Thanks, import/lef: it goes without saying!
Worked just fine.
Cheers,
C.
