Sep 3rd, 2024, 7:21pm
Real freq, Imaginary freq, positive freq and negative freq  ??? (Read 4053 times)
rajkumar palwai
Sunnyvale, California
Oct 25th, 2011, 10:28pm
Can someone explain about the real freq, complex freq, positive freq and negative freq ?
I use all of them while constructing root locus, bode plots and power spectral density's, but somehow i don't understand them intuitively.
For eg: what is the real meaning of negative freq? Is it same as positive freq with 180 def phase shift?
rajkumar
buddypoor
Bremen, Germany
Re: Real freq, Imaginary freq, positive freq and negative freq  ???
Reply #1 - Oct 26th, 2011, 12:42am
rajkumar palwai wrote on Oct 25th, 2011, 10:28pm:
No, there is no real world "explanation" for the term "negative frequency" because they do not exist in reality.
They only are a mathematical tool with the aim to describe the frequency spectrum in a compact form (using exponential functions).
raja.cedt
Reply #2 - Oct 26th, 2011, 12:50am
hello rajkumar,
for any  physicall signal only +ve frequency posb, but to represent a real signal in complex plane we use both +ve and -ve frequency, for example  coswt=(e(iwt)+e(-iwt))/2, so here by using -ve frequency we represented a real signal. Otherwise think from vector point of view, any phaser can be represented by horizontal and vertical components.
Small corection to your post:
A.-ve frequency term will be used in PSD (by the way for real signals no need to use -ve frequency because PSD symmetry, just represent PSD in +ve frequency but magnitude will be increased by 3db ), in bode and root locus we dont use -ve frequency term at all.
B. what do you mean by complex frequency??
raj.
rajkumar palwai
Reply #3 - Oct 26th, 2011, 9:24am
@Raja and @buddypoor,
Thank you for ur explanations. Now got some sense of positive and negative frequencies.
Can u also explain the real and imaginary freq ?
For eg: In a transfer function, say we have got a zero @ -x1 + j(0). So, what is the meaning of -x1 here. Any real world sinusoid signal is represented as imaginary freq. If we do a real world ac sweep on the circuit, the o/p ac magnitude will start rising @ 20dB/dec from a real  freq of mag(X1).
So why we have represented the zero as -x1 + j(0) and why not 0 + j(-x1) ?
rajkumar
raja.cedt
Reply #4 - Oct 26th, 2011, 10:17am
hello rajkumar,
in the transfer functions we use state variable S, means σ+j*w, here σ means attenuation (neper/sec) and w is frewunecy (rad/sec) under the assumption of you are appling a signal called exp(-σ+j*w)t otherwise a sinusoidal signal with frequency w multiplied by exp(-σt). Noramally we will draw bode plot by assuming sigma=0, but you can 3d plot. So coming to your last point (x1+0*j means no frequency at all, it's DC) and if you represent 0+(i*x), it's frequency. There is no img frequency, up to my knoledge. We will consider img part of a S is called frequency.
raj.
Reply #5 - Oct 26th, 2011, 12:07pm
Complex Frequency - This is a concept that does not get used much in practice.
Most people work with constant amplitude sinusoids (the radians/sec part of complex frequency)
And don't deal with signals that have an exponential envelope coefficient ( the σ part)
"the general complex frequency, s, can be thought of in terms of its real and imaginary parts:
s = σ + jω
or in terms of its period and periodic decay rate:
s = T-1ejα.
The former is always the most appropriate way to use the complex frequency in a Laplace or Fourier transform, however the latter offers a bit more insight.
The imaginary part of s:
Im{s} = ω
is what you would normally think of as "frequency." It tells you how often the signal goes from positive to negative. The real part of s:
Re{s} = σ
is what you would normally think of as "decay rate." It tells you how quickly the amplitude of the oscillations change."
from: http://www.physicsforums.com/showthread.php?t=37945
Above is a pretty good explanation. Wikipedia could use a good write-up on this one.
