Sep 5th, 2024, 1:13am
measuring op amp specs (Read 2415 times)
mixed_signal
Oct 30th, 2011, 12:53pm
I have designed a single input single output  amplifier for low power applications. It has dynamic biasing and has two phases: biasing phase and amplifying phase and has clocks. I want to measure the slew rate, settling time, input reffered noise, input comon mode range, output common range, offset. How can i measure them systematically.
For slew rate measurement, i know that opamp is configured as voltage follower and then step input is given. What should i do in case single input single output case?
Should i use any feedback?
raja.cedt
Re: measuring op amp specs
Reply #1 - Oct 31st, 2011, 1:26pm
What do you mean by dynamic biasing, is bias current chages over the operation? Any how to for all measurements use feedback at least dc -ve fb and may be for ac openloop is ifne.
raj.
mixed_signal
Reply #2 - Nov 1st, 2011, 7:06pm
Yes the bias current changes and more important is that the amplifier has a biasing phase where it is switched to biasing circuitry and gets biased. During amplifying phase input is applied and biasing circuit is cut off. There are capacitors to keep it biased.
weber8722
Reply #3 - Nov 17th, 2011, 8:03am
BTW, measuring SR as follower is not always sooo good. Image your output is rail-to-rail, but input not. So you will overdrive the input, if this is not the case in your real application you may get inconsistant results.
Better always do both standard tests and test very close to the actual application (maybe a 100X-amp, not a unity-gain-buffer).
