Sep 4th, 2024, 11:19pm
Bandwidth of Oscillator (Read 975 times)
Brandon
Nov 16th, 2011, 1:37pm
Attached is schematic of oscillator whose output frequency depends on the LC tank circuit. The inductance by which this oscillator seems to be 'stable' is 1nH - 10mH. I need to know what is the purpose of the negative feedback with a bypass capacitor to ground and the purpose of the resistor network on top. Is there an effective way to modify the circuit to handle higher inductor values?
thanks
raja.cedt
Re: Bandwidth of Oscillator
Reply #1 - Nov 16th, 2011, 1:58pm
hello,
1.What is your Frequency of interst? Why you want to maximize the L, you dont have smaller inductors?
2. -ve feedback(at least DC) through is essential because you need -ve resistance to compensate finite Q of the tank. Top resisters are for biasing the opamp i guess.
3. Try to post small schematics so that it will easier to view.
Raj.
Brandon
Reply #2 - Nov 16th, 2011, 2:25pm
This oscillator will be used to determine the value of inductance or capacitance by measuring the output frequency from a microcontroller.
That is why I need to increase the bandwidth. The circuit is attached again.
aaron_do
Reply #3 - Nov 16th, 2011, 11:14pm
Hi Brandon,
I think the negative feedback is used to provide a DC bias to the negative input pin of the op-amp. If you want the circuit to work for higher L values, maybe you can increase the size of the two large capacitors. You should simulate it to verify.
regards,
Aaron
buddypoor
Bremen, Germany
Reply #4 - Nov 16th, 2011, 11:59pm
Yes, of course the negative R-C feedback is necessary to ensure a bias point at approx. half of the supply voltage.
This is the clasisical bias concept for single supply circuits:
DC bias at the pos. input and negative feedback for dc unity gain of the opamp.
