mixed_signal
Hi, I have designed a single input single output amplifier for low power applications. It has dynamic biasing and has two phases: biasing phase and amplifying phase and has clocks. I want to measure the slew rate, settling time, input reffered noise, input comon mode range, output common range, offset. How can i measure them systematically.
For slew rate measurement, i know that opamp is configured as voltage follower and then step input is given. What should i do in case single input single output case?
Should i use any feedback?
