Jul 16th, 2024, 7:51am
PLL loop parameters (Read 3872 times)
pumba007
PLL loop parameters
Nov 05th, 2011, 9:51am
I am running a PLL with individual block coded in verilog A.
ref = 104MHz
divider ratio = 28
vco output = 2.912 GHz
What should be the cutoff frequency of the Low pass filter which immediately follows the charge pump which pumps or sucks 100mA.
can somebody explain the relation between chargepump current, filter cutoff and settling time of the PLL. Volatge 0 to 1.
Thanks and regards
manikandan
raja.cedt
Re: PLL loop parameters
Reply #1 - Nov 5th, 2011, 11:16am
hello,
could you please elobarate your question more? What do you mean by cuffof frequency?
may be you are intersted to calculte loop filters parameters like Icp,R1,C1,C2.
you can chose your Pll BW <10.4Meg, so for this use simple expressions to find all components.
raj.
pumba007
Reply #2 - Nov 5th, 2011, 11:40am
i was talking about the low pass filter cutoff frequency used to calculate c1, c2 and r.
i remember reading from somewhere that this frequency is usually about 1/20 of the reference frequency..is that right?
thanks
manikandan
Reply #3 - Nov 5th, 2011, 1:14pm
THis is in a bunch of textbooks on PLL's and control system theory.
Online:
www.freescale.com/files/rf_if/doc/app_note/AN535.pdf
www.ti.com/lit/an/swra029/swra029.pdf
and others...
