raja.cedt
hello rajkumar, I guess jitter will increase with pulse width, because more time both and dn will be on so more charge pump noise. However your example of KT/C has no proper correlation here, becaz there Power Spectrul density increases with R and integration BW decreases with R, so you there will be no effect of on the total area, where as in case of pll Charge pump noise pSD depedns on the chargepump current and many other parameters but integration BW depends on PLL bw.
correct me if i am worng Thanks, Raj.
