Jul 17th, 2024, 7:43am
Pages: 1 2
CMOS Passive Mixer (Read 13464 times)
rfmagic
Re: CMOS Passive Mixer
Reply #15 - Nov 15th, 2011, 7:05am
Thanks aaron_do, I think I get the idea. With the resistive load you get the instantaneous sample of the RF at the IF output while the capacitive load performs an integration of the samples as long as the IF BW is low enough to make the charge-discharge cycles within Fif frequency.
I appreciate your help on this...
aaron_do
Reply #16 - Nov 15th, 2011, 4:34pm
Hi rfmagic,
both cases you are essentially "sampling" (not to be confused with actual sampling as in data converters) the RF sine wave. For capacitive load you are charging and discharging, for resistive load, the power is consumed in the load.
regards,
Aaron
Pages: 1 2
