Jan 20th, 2026, 3:50am
counter (Read 3596 times)
techkid_15
counter
Nov 10th, 2011, 5:49pm
I am trying to make a counter that goes from 0 - 999 on the rising edge of the clock.  I am using the Nexys 2 FPGA board, so I have a 50 MHz clock, and I am using the 23rd division, or 2.98 Hz.  I have 4 modules and a top level file.
Top Level File:
module binbcd10_top(input wire mclk, output wire [6:0] a_to_g, output wire [3:0]an,
input wire [3:3]btn
wire [9:0]w;
wire [11:0] pp;
binbcd10                  U1            (.b(w),
                                         .p(pp));
mux7seg                  U2            (.a(pp[3:0]),
                                         .b(pp[7:4]),
                                         .c(pp[11:8]),
                                         .d(4'b0000),
                                         .mclk(mclk),
                                         .a_to_g(a_to_g),
                                         .an(an)
counter                  U3            (.p(clk),
                                         .clr(btn[3]),
                                         .w(w));
counter_clk_div      U4            (.clr(btn[3]),
                                               .mclk(mclk),
                                               .clk(clk));
Binary to Decimal Convertor:
module binbcd10(input wire b, output reg [11:0]p
reg[21:0]z;
integer i;
     always @ (*)
           begin
                 for (i=0; i <= 21; i=i+1)
                 z[i]=0;
           z[14:3] = b;
                 for (i=0; i<5; i=i+1)
                 begin
                 if(z[13:10] > 4)
                 z[13:10] = z[13:10] + 3;
                 if(z[17:14] > 4)
                 z[17:14] = z[17:14] + 3;
                 if(z[21:18] > 4)
                 z[21:18] = z[21:18] + 3;
                 z[21:1] = z[20:0];
                 p = z[21:10];
This tells it how to display numbers on the 7 segment displays:
module mux7seg(input wire mclk, output reg [6:0]a_to_g, output reg [3:0]an, input wire [3:0] a,
input wire [3:0] b, input wire [3:0] c, input wire [3:0] d
wire [1:0] s;
reg [3:0] y;
reg [19:9] clkdiv;
assign s[1] = clkdiv[19];
assign s[0] = clkdiv[18];
always @ (*)
case(s)
0: y = a;
1: y = b;
2: y = c;
3: y = d;
default: y = a;
endcase
always @ (*)
case(y)
0:a_to_g =7'b0000001;
1:a_to_g =7'b1001111;
2:a_to_g =7'b0010010;
3:a_to_g =7'b0000110;
4:a_to_g =7'b1001100;
5:a_to_g =7'b0100100;
6:a_to_g =7'b0100000;
7:a_to_g =7'b0001111;
8:a_to_g =7'b0000000;
9:a_to_g =7'b0000100;
'hA:a_to_g =7'b0001000;
'hB:a_to_g =7'b1100000;
'hC:a_to_g =7'b0110001;
'hD:a_to_g =7'b1000010;
'hE:a_to_g =7'b0110000;
'hF:a_to_g =7'b0111000;
default
a_to_g=7'b0000001;
endcase
always @ (*)
begin
an = 4'b1111;
an[s] = 0;
always @ (posedge mclk)
clkdiv <= clkdiv +1;
Counter:
module counter(input wire p, output reg [15:0]w, input wire clr
always @ (posedge p or posedge clr)
begin
     if(clr == 1)
           w <= 0;
     else if(w == 999)
           w <= 0;
     else
           w <= w +1;
Clock Divider:
module counter_clk_div(input wire clr, input wire mclk, output wire clk
reg[23:0] q;
assign clk = q[23];
always @ (posedge mclk or posedge clr)
begin
     if(clr == 1)
           q <=0;
     else
           q <= q +1;
Right now, it is just alternating between a 0 and 1 on the far right 7 segment display.  I appreciate any help.
boe
Re: counter
Reply #1 - Nov 11th, 2011, 8:14am
techkid_15,
Bug in interface of binbcd10 (port b) block.
- B O E
